cemetery gates
09.14.2006, 04:39 PM
Originally Posted by BADBOY2
so ineed external bec so i can run my 12cells?
what if i run 1 pack of 4200mah 2s2p lipos?will it make a difference versus 12cells of 3800mah packs in series?
and so after i take that center red wire i can just plug my batts or i need to do something else?and will i still need the external bec?or i can put the external bec and leave the red wire connected?
2s2p is only 7.4v so you would need a 4s2p to run like 12 cells (14.4v) (actually you wuold run better on lipo)
You also NEED AN EXTERNAL BEC like a UBEC or RECIVER PACK. you can't just pull out the red wire. (you need it disconected with UBEC).
