How do you shim the FLM combo bulks? -
09.15.2006, 03:04 AM
I replaced the ring and pinion in my front diff tonight. I put the combo bulk back together and the gears were binding when turned. If I would loosen up the bolts holding the combo bulks together, it would free up a little and wouldn't bind as bad. I don't remember it binding this bad before. What's up?
Thanks.
