Thread: Hyperion EOS 7i
GeeReg
GeeReg's Avatar
09.15.2006, 12:12 PM
Originally Posted by neweuser
That's what i'm thinking. But i triple checked the settings. Brian G asked the same question basically. I think i'm returning the charger. IMO, it should be able to be set and charge without getting the error message! Any other opinons with this specific charger would be greatly appreciated! If i try to charge in series, it tells me output voltage to low, yet i'm pushing more than 12v to the charger. When i charge batts in single, then it tells me that the "output voltage too high"? What is the deal!
Mine does this when charging single cells. I found that it's because the charge rate is set too high, although it shouldn't matter. If you turn it down to under 1 amp, it should be ok.
RC10T2 - Novak SS5800 - 7-cell GP3700
HPI RS4 Nitro MT - Mamba Max 5700 - 2S 5500mah Lipo
MRC Thunder King - Mtroniks Truck ESC + Feigao 9L - 3S 6000mah Lipo
