09.15.2006, 12:17 PM
Sounds like it needs a firmware upgrade.
It can charge with a certain amount of power, when the cells get full, the current stays the same, but the voltage gets higher, meaning it needs to put out more watts in total. Since there is a limit in watts it can deliver, it's likely that this is causing the problem.
Sounds like you set it to the maxximum amount of current to charge with?
