squeeforever
squeeforever's Avatar
09.16.2006, 12:33 AM
Trust us on this, if you want speed, a lower kv motor and a higher cell count will be more powerful. The 4600 on 4S would be my choice as well. If you want speed, forget the Novak... Sensorless is the only way to go. Plus, the Novak doesn't even have a built in LVC like the CC controller. The reason to go with a 4600 is simple...The 4600 will pull less amps then the 7700, will heat up less from less strain, can pull a higher gear, will have more torque (which allows the higher gearing), and a couple others. If you want speed, look at all the other people with those speeds. There running a high voltage setup. Not a high kv. A high voltage setup will be more efficient and will be easier on the batteries, providing more power...
Edit: Damn...You beat me to it, Metalman...
