Thread: Its complete
cemetery gates
09.17.2006, 04:35 PM
Originally Posted by Puttinstankonia
its the red triton charger and it will only allow me to charge at 14.8 volts... but I am runnin 16.8 by mistakes.(packaging mislabeled) so do u think that the LVC on the Quark worked and my charger is the problem or is it the batteries them selves... is the LVC on the quark automatic?
if you are running a 4 cell lipo its nominal voltage is 14.8, its max voltage is 16.8, and its discharged voltage is 12 volts(assuming you set 3.0 volts per cell cutoff, the lowest you want to go)
you have to program the lvc on the quark.
