Originally Posted by Finnster
From what I've seen, the 12t Titans are meant for 6-7 cells, not 14.
Actually, they can run off 14 (2x7 cells) i think is what he means. And a single speed would give him more room to mount stuff. Having ALL four mounted screws reallt isn't needed. If i can run my single speed on BL he should be fine IMO.
But would still go BL as it will cost almost the same to get the set up he is looking at. Really, an xl motor and esc from mike would only be 300.00 for a cheaper set up.
