09.20.2006, 11:32 AM
Perhaps putting the cells more to the front would help too.
Any truck likes to balloon in the front, because the pressure is larger on the rear tires.
i don't know what the boiling point of silicone is, but i doubt if you are able to reach it in a diff.
You could get a tad heavier oil. 100K would be good to use, if 50K balloons too much. and with the tires duct-taped the ballooning of the front tires will be almost gone.
What tires are you using? and on what surface? the grippier the tires, the less fast they will loose traction.
