Sower
Sower's Avatar
09.26.2006, 10:47 AM
Hey guys, thanks for keeping this going. I've ordered the 12 tooth pinion from the site here, and I think I have found a place that has Mod1 pinions with 1/8 shafts from 10 and 11 teeth. I really think that's the challenge. If the pinion doesn't work, then I'm going to get a Neu motor. I don't have anything against the 4600, but I don't want to be limited by it either. The Mamba Max controller will work fine if the motor is running efficiently. Plus, I think I would have to change my battery setup with the 4600 to get proper voltage. Right now I have two 11.1v 3100 mah 3c Polyquest li-po's in parallel. I'm still learning a lot though, so maybe not.
