smhertzog
Breaker of all that is Stock
smhertzog's Avatar
09.26.2006, 03:40 PM
Originally Posted by Cartwheels
I ran the buggy again sunday late in the day. Ran it as hard as I could for 25 minutes straight. Temps were great. At the end of the run the heatsink was 132* and the board where the motors wire come out were actually 5 degrees cooler than the heatsink. I've never seen that before. I'm really happy with it so far.
Here is a picture of the buggy. The Quark is mounted upside down and also I threw in a picture of the open ends of the Neu motor, which I later taped up.
Sounds like you may have got something there, I'm just wondering how much of the heat drop can be due to the neu motor. That and the ambient outside temperature make a big difference. I just noticed mine is loose and am going to do some changes. The shrink wrap on my caps looks like it got hot and came off, they read 35v 330uf . Im also wondering if the fact that only one bank of the fets is connected to a heatsink that sees airflow has anything to do with the overheating.
Never fight an ugly man..... he has nothing to loose
