Serum
Serum's Avatar
09.26.2006, 05:54 PM
LST shafts are not thick?
the difference between the UE 6 and 8mm is only the output shaft..(the part that mounts to the hex./wheel one is 6, while the other is 8mm. you also need knuckles that fit the bearings needed for the 8mm's.
