Originally Posted by aqwut
hmm... I guess I'll just stick to the 6mm to save the hassle... but doesn't the rpm knuckles support the 16mm bearings?...
No, they do not support 16mm bearings, only 15mm.
PER THE RPM WEBSITE:
http://www.rpmrcproducts.com/product...2.htm#knuckles
T/E-Maxx 1.5 & 2.5 Axle Carriers
T-Maxx 2.5R & 3.3 Owners - Click Here for the proper Axle Carriers for your truck.
Stock bearings and axle carriers aren’t quite strong enough to handle the punishment T/E-Maxx owners dish out. In addition, more strength is needed at the axle carrier when offset wheels are used or when aluminum accessories and oversized wheels & tires add more weight and stress to the driveline. Once again, RPM steps in where no one else has! We have completely redesigned the axle carriers for the maximum amount of strength and durability and included some seriously beefy 15mm. bearings to top it all off! Check out this incredible list of features:
RPM Axle Carriers
Stock replacement – no modifications necessary for RPM carriers to fit.
Larger bearing bores that accept RPM Oversized 15mm. bearings.
Includes four RPM 15mm. bearings in the kit – nothing more to buy.
Beefier, thicker walls and ribs for the ultimate in crash protection.
Double-ribbed steering arm / toe link arm for undeniably stronger and more rigid steering control and toe angle stability.
Stepped front surface to prevent plastic wheels from hitting the axle carrier under high cornering & jumping loads.
Molded from our bulletproof and lifetime guaranteed blend of nylons for unsurpassed breakage protection.
Molded in black, blue, & purple, as well as a dyeable white, that will allow anyone the most versatility with respect to color choices.
Stock 12mm. vs. RPM 15mm.
RPM Oversized 15mm. Bearings
A full 15mm. in diameter – that’s 3mm. larger than stock!
1mm. wider than stock bearings, with 2 bearings per axle, that’s an extra 2mm. per axle of contact with the axle shaft for smoother, longer-running performance.
100% Stainless steel construction for rust free dependability and its longer-wearing characteristics versus chrome steel bearings.
RPM Bearings have friction-free blue nylon seals for the ultimate in dirt protection and can easily be cleaned using our RPM Bearing Blaster (#81170).
Actual bearing ball diameters are a full 33% larger than stock.
RPM oversized bearings have more than twice the load rating of stock chrome steel bearings and have over three times the fatigue life of stock as well!
Prelubed with lightweight oil for efficient & minimal rolling resistance.
RPM axle carriers are sold in pairs. One truck will need two pairs to cover all four corners of a T/E-Maxx truck for complete, RPM bulletproof protection. RPM replacement oversized bearings are sold in sets of four bearings per package.
Tech Notes: Associated MGT owners can benefit from using RPM Steering Knuckles / Axle Carriers by combining these axle carriers with our #80010 Pillow Ball Setscrews & Bushing Caps. This package comes with spacers that prevent the bearings from binding on the MGT. Read more here.
80031 Dyeable White Knuckles w/ Bearings
80032 Black Knuckles w/ Bearings
80035 Blue Knuckles w/ Bearings
80038 Purple Knuckles w/ Bearings
80060 Replacement Oversized Bearings (4)
Suggested Retail
Carriers & Bearings - $26.95 / Pair
Replacement Bearings only - $15.95 / Set of Four
