09.27.2006, 04:23 PM
I totally agree. Even different colours act different (the purlple on the GP3300's can be like 65 degrees, while the metal is 40 degrees..
that's a pita. i try to measure on silver parts, that seems to be the most accurate.
Normally you use it as a reference, if you measure on one point, gear it different and measure it again on that certain spot, you know what the result is/was.
