MetalMan
MetalMan's Avatar
09.28.2006, 11:34 PM
Something for you to think about, you could go with a rectangular tube instead of a solid block to reduce weight. Something like this might work:
http://www.industrialmetalsales.com/1972.html
It's 12.75mm tall instead of 9mm, and 25.4mm wide instead of 20mm. I think 6063 is just a more corrosion-resistant version of 6061, and it should definitely be strong enough (the walls are 1/8" [3.17mm] thick).
