10.01.2006, 12:37 AM
Not really much to see since it's basically en empty chassis.
The two attached pictures are the two battery placements I was looking at. I figured on worst-case battery size of 150mm X 50mm. The battery tray will be a smidge bigger (~4mm width and height). Either layout leaves a little bit of the pack off the edge (red circle) although the angled one is not quite as bad. The straight layout looks better though.
