Thread: Cell Pro LVC
MetalMan
MetalMan's Avatar
10.01.2006, 08:53 PM
I updated the other thread with the correct wiring diagram for the LBA6.
To wire the Cellpro LVC, you'll need to connect the same wires to it as you would to the LBA6 in the same order, except for the outer two wires (the ones that branch off) that aren't used. I don't know which connector (if any) is on the Cellpro, but if it's a 5-pin connector, then you're going to have to make another adapter.
