Finnster
KillaHurtz
Finnster's Avatar
10.01.2006, 10:53 PM
Originally Posted by Rtsbasic
Wow, 7KG!! Hows that shift? Does 18 cells really make that much of a difference or does it come out a bit under powered? Guess at least you can brag about having a massive truck :D
Finnster, nice, my Savage is only 450g heavier RTR than your Revo, my setup and projected speed should end up rather similar to yours then? With mambamax, 8XL, 14 cells.
I would think it would be pretty close.
My Revo is a bit of a :040:, but its not too bad. The motor and batts alone are over 1.5 kg! Otherwise the conv did not add much weight. Everything other than the BL is bone stock, so there is a bit of fat to trim, but that's the next project.
