05.11.2005, 07:52 PM
Is it necessary to use 2 transmissions? I haven't used a twin force tranny, so I can't comment on its abilities, but the e-max tranny is pretty tough. If one transmission is possible, one motor could accomplish your speed/power goals with enough cells and the proper gearing. No problems. If two trannies is an absolute must, then two motors, controllers, ad ideally two battery sources could quite easily power this rig. How many cells are you planning? any idea what your final gear ratio will be?
