MetalMan
MetalMan's Avatar
10.06.2006, 05:14 PM
Originally Posted by Wittenborn
What other motors can be recomended that gives the same or more power/torque as the 7xl. with the Quark 125B
(for an E-revo with 2x7 cells /2s2p 8000 mah lipo)
Most likely you won't be able to find a motor that can push out more power than a 7XL without paying a lot more. But keep in mind that the batteries supply the power, so better batteries will allow the motor to be more powerful than cheaper batteries. Also, if you use more cells, then you will get an increase in power.
