squeeforever
squeeforever's Avatar
10.06.2006, 11:36 PM
The different KV ratings are of RPM's per volt. You multiply the KV times the total voltage and thats your motor RPM's. I would shoot for around 35K. You should get 40+ mph pretty easy on 14 cells. As for diffs, what I would do is get the FLM hybrid bulkheads and some HB Lightning diffs. There a little expensive, but WELL worth it.
