10.07.2006, 10:07 AM
If you've been driving your truck, you most likely bent the hinge pin. Since aluminum doesn't want to move to the new curve of the hinge pin, it gets stuck. If you have a dremel you can try cutting the pin into pieces, and then pull them out.
