rchippie
rchippie's Avatar
10.10.2006, 05:37 PM
What i do sinice i dont have a gear puller here is what i do . First you take off the clutch bell & clutch shoes & clutch nut. Then you turn the motor over & put the crank shaft on something solid. Then i take a adjustable wrench & adjust it to fit the back side of the flywheel & tap both sides with a hammer & the flywheel pops right off. I hope this helps :027: .
REAL MEN RUN BRUSHLESS
