10.10.2006, 06:47 PM
Let me know how it goes with the spectrum mate, I'm thinking of upgrading the radio anyway - the recievers been repaired that many times i've lost count.
Used the lowest timing setting on its first run, to be on the safe side. Bumped that up to "low" for its next test run tomorrow. Also changed the start power to "high". If the temps are still good I'll keep playing with the settings.
Re-did some of the wiring tonight, moved the UBEC off the powercables, made & mounted a lexan plate for the esc over the gearbox, and fitted a 40mm fan. Will snap some pics tomorrow, it don't look too bad although the shape of the esc ment it wasn't quite as tidy to mount as my 9920. I can access the USB port fine without taking it out the car though.
