10.12.2006, 12:52 PM
First, you need to make sure your charger can do it. If you only have one output, make a series adaptor as you would for the controller. But I don't think your 636 can charge a 6s pack can it? I know the 977 can't do 6s. Also, once you have the charger that can handle the two, if you use in series, then charge in series.
when charging in series, it would like charging ONE pack.
