Finnster
KillaHurtz
Finnster's Avatar
10.12.2006, 04:12 PM
You may not be actually voiding the warr then.. :) But still I would highly recc a UBEC or Rx pack. They are not that much and saves alot of heat at a high cell count. You've seen this in other threads that the BEC sheds the voltage (from 14.4V to 6V) as heat, so the higher the V, more heat is created. Couple this with a big motor, and you may get a toaster. If you really want, try it, just keep an eye on temps.
