James
10.14.2006, 04:35 PM
Originally Posted by chilledoutuk
well if theres a problem with the bec on your computer just get a UBEC and use that instead should be ok on 12 cells then.
TBH the mgm controllers are not the best example of where sensorless technology is nowadays with the braking problems etc but those problems are probably fixed now in the latest software.
The grasshoppper is a very simple car and originally came with a 380 size motor i suspect that one of the purple can feigoa motors would fite nicely if you get low enough kv you could use a mamba 1/18th controller if you use a higher voltrage with low kv motor you could use cells smaller than subc for this or possibly lipo.
I have the hornet but the tranny/axle housing is craked, so when i replace it i was going to ge tthe grasshopper one instead so i cna gun the mamba system. I can get the hornet part, and run a 540 size motor to. I have a could i run the wanderer 12s on 8 cells? would that have to much torq? how fast would it go?
