MetalMan
MetalMan's Avatar
10.15.2006, 05:05 PM
In the pictures you don't show the series "Y" adapter connecting the main power leads of the batteries together. I just want to make sure that you are using that and it is hooked up properly. From the first picture in post #8, you would have the series adapter set up so that the positive of the right battery has a wire connecting it to the negative of the left battery, with the left battery's positive going to the ESC and the right's negative going to the ESC.
