Tazz
Custom
10.17.2006, 07:31 AM
Originally Posted by BrianG
As you can see by my TP tube mockup, there should be enough room for the body to fit over the motor. The body does bubble a little above the mounting spot, so it should be OK.
I ment if you flip the plastic diff support upside down. By doing this it will raise the center diff and expose the spur gear for pinion gear clearance, but may raise the motor too high and interfere with the body.
