skellyo
skellyo's Avatar
10.23.2006, 11:33 AM
Originally Posted by TexasSP
One frustrating thing is that the kit says it comes with everything.
Everything that is except the rod ends. My question is which ones do I need to use? The maxx ones have an inner diameter that is too large so I was thinking These would be the correct match.
Also, with the arm part of the kit there are to pieces of aluminum about 3/4 to 1" long and 1/8" wide with a hole at each end that I can't quite figure out what to do with. Any help is appreciated, maybe I am just blind to the obvious but it has me confused.
The Traxxas rod ends you linked should work fine.
If these are the parts you're talking about http://onelouds10.com/flm_what.jpg they attach to the bottom of the rear a-arms.
