jhautz
jhautz's Avatar
10.25.2006, 01:45 AM
Originally Posted by glassdoctor
I was wondering about target speeds for this... fdr and the tire diameter to get estimated speeds for your setup. I don't know what the tire dia is though.
But knowing that the nitros can hit 70mph... and guessing that the nitros likely max out around 40k rpm?? Just duplicate whatever rpms they are pulling and you will get the same top end... or beat them by a little bit. ;)
Nitros are 2 speed trannys. This is a single speed. Are you just running using 2nd gear only like an emaxx? Or are you using a diferent gear ratio?
to make it...
or break it...
Silent...But Deadly
