Originally Posted by E-Maxx King
So what does the runtime compared to a HV 6.5? So with a bec on the CC, 14 cells will be fine? Could I run a BEC on the EVX? So it could handle 16 cells?
Well, the HV 6.5 is a lower power system, so runtimes will be longer. However runtimes with above setups are not bad. I get ~10 min hard non-stop bashing w/ the 8xl on 2800 mah (what the batts charge back to.)
