MetalMan
MetalMan's Avatar
10.25.2006, 04:37 PM
Originally Posted by natrix
I know it's a little old, but I wanted to drag this one up. When connecting batteries in parrallel, is it still safe to assume that both packs must be within .05 volts of each other? And when charging the packs, can you just use the same harness used to parrallel them and charge at 1C?
0.05v difference is okay for paralleling packs.
You can charge them in parallel, but if you're not using balancers, then it would be a good idea to check the cells' voltages.
