Originally Posted by vette1
The stock slipper sucks - I tried it twice. Even when I accelerated slowly and change my gear size it still burned up. Thats twice in two runs.
Anyway I will probably order the strobe slipper kit. But since there not in stock I did some research and found a Robinson Racing slipper kit. All metal and has holes in it for cooling like a disc brake. Not sure if it will fit on the emaxx tranny. Also, I believe it is a 32pitch spur so I order RR pinions to match. Hopefully I did it right and won't have a problem with installation or running it.
I also checked the car on the speed gun and reached 57mph using 52spur and 18 pinion. My goal was 60 and I think I will achieve it once I use the all metal slipper.
I'll keep everyone posted on when I crack the 60mph mark.
You need to get the plastic spurs....The metal on metal will shred the pinions...Did you get my PM?
