10.29.2006, 06:51 PM
Well I tried it again and I melted the spur gear a second time. Top speed using a 52/16 was 57mph and I plan on breaking 60 before I'm done. Mike is still out of the strobe slipper so I searched the web and found Robinson Racing. They make a 32pitch 54spur and 14-22pinion gears with an all metal cross drilled slipper. I'll try this configuration on Wednesday when I get it in the mail and tell you all how it works. I will start with a 14pinion then 16 - 18 - 20 and finally if the E-Revo can handle it a 22.
Well what do you guys think about my idea of using the RR slipper as a substitue?
also, what does everybody think about the RR slipper with the plastic spur instead of steal?
I'm crazy and I'm not afraid to talk about it.
