10.30.2006, 12:42 AM
GD: The Quark 125B is nice, but I think the MM is better in some ways. Plus, the footprint is much smaller. Personally, if you never plan to go above 4s and 100A continuous, I'd stick with the MM. Even then, the MM has been unofficially said to be able to use 5s. The Quark has trouble at 6s, so it is effectively a 5s ESC unless they have fixed that issue by now. So really, you're not gaining much voltage-wise with the Quark.
If you want to "feel" the Quark before using yours, you can test drive my Revo sometime if that will help.
BTW: you have two MM or regular Mamba systems coming? Is it a motore/ESC bundle or just the ESC?
