05.18.2005, 09:20 PM
Even the 2800 will be quite warm with that voltage. Most motors are at their highest efficiency(lowest heat generated through inefficiency) in the 30-40k rpm range. Of course, it is your choice. The 2800 will be quite the animal on 22.2 volts. I think you are perhaps underestimating the power you will have. Be sure to get some video! The truck is going to scream!
