Originally Posted by tallyram
when i turn it on i have to hit reverse throttle before it will make the last series of beeps and start working. don't know what thats about! sorry for the hijack, i'll shut up now!
You need to reset the neutral point. You probably moved the trim on the throttle a little. Just rerun the initial setup on the controller and that should go away.
