10.31.2006, 10:58 AM
Nick: This is exactly why I'm going to factor weight in the motor selector calculator. Someone could even enter in the kv for a regular mamba system (which has a high kv) and the numbers on paper would look impressive even though real-world results would be disappointing to say the least! Too bad most motors don't specify the torque rating...
I started work on the new version last night. While I'm at it, I totally restructured the layout to have each seperate section in its own web page (using frames). There was just too many lines of code for easy editing. It's not close to ready yet, but for those wanting to see the progress, I will have the beta version uploaded here.
I figure the best way to handle the weight factor is to suggest the motor size by weight, and then the wind/kv by voltage used. I'm thinking of using this as a guidline for weight:
0-2 lbs = 380 can size (regular Mamba system?)
3-5 lbs = 540 "S" can size
6-9 lbs = 540 "L" can size
9-15 lbs = 540 "XL" size
13+ = 540 "XXL" can size or something like the 22xx LMT series.
How does this look?
