Finnster
KillaHurtz
Finnster's Avatar
11.01.2006, 04:55 PM
Originally Posted by crazyjr
Based on this thread I have been wondering if i needed to run a 7XL instead of the 9XL in my G2R 12 cell mamba max setup. Given the same gearing (17/66) and same cell count (12 cells), Could the 7XL be more efficient in this case?
As daf said, you couldn't gear it the same. Assuming both are properly geared, it doesn't mean the 9xl is inefficient, altho it may be just slightly lower. What you can't do is try to gear the 9xl for as high of speed as the 7xl is capable of w/o overgearing/overloading the motor and thus dropping efficiencies
SScream: you evil man....:mad:1 :005: I doubt and diff would be readily noticeble, all winds seem capable of v high efficiencies.
