Originally Posted by BrianG
Glassdoctor: I checked out the Jato setups but haven't gotten around to implementing them yet. I'm actually pretty happy with the setup if I could just get some decent tires. I've worn out another set of stockers. Imex is the only company that carries 2.8" rims and tires with pins and some stuff is out of stock right now. 2.2" rims won't work for me because I'm using RPM arms and you need to do some mods to use 2.2's, which I don't want to do.
Well, since this has been reopened, I'll let you know Brian that I run 2.2 rims on my Jato and did not have to mod anything? So i was curious to what you mean there. Also, if you shop around, I have been seeing new tires and rims for the Jato that are 2.8's. Or at least my LHS had new kind of 2.8 tires for the 2.8 rims, something like that, but I have seen them.
