squeeforever
squeeforever's Avatar
11.04.2006, 06:06 PM
OK I'LL LOK AT THE PIC! lol...Anyway, how many did you order? 1 or 2? If one, you need to make an adapter to balance them both at the same time or just charge both to about 90% capacity and then do them individually to 100% with the balancer (if you need 100% capacity). If two, then just charge the packs through the Deans with the charge and hook the taps of the batteries up to the balancers and don't worry about the input. That balancer is made to charge/balance inline. Or, since you will only be charge at 2.5 amps, simply charge both packs at the same time using a Y adapter on the charger going into the two balancers (if you got two like you implied) and then the taps of the batteries going into each charger so they are being charged at the same time but being balanced by 2 difference balancers. Understand? Basically just tell me whether you have 1 or 2 balancers...
