05.20.2005, 07:04 PM
The 6s is not really a good motor. I really don't recommend that motor for anything but say drag racing. That motor works well if it's got a pretty big pinion, batteries that LIKE to give over 100 amps etc.
The TC4 is much better off with a "380" size rotor. So, motors such as the Lehner 1520, 1525, Hacker C40 S, Kontronik Twist are probably the ultimate motors for a 1/10 TC. The Basic series and Plettenberg are a bit larger and need more power to get them going and so I don't think those are the ideal motors either.
That motor has a really heavy rotor too. BTW, are you sure you got the MGM programmed right?
