11.05.2006, 01:03 AM
I have a question for you: Are you sure you are having an error? I just looked at the description of the balancer and saw these two last bullet points:
- LED of the lowest voltage cell: Off. LED of higher voltage cells: Flashes.
- Err/Check LED will flash, if you choose unmatched adaptor.
It sounds like the error light flashes if there is an error. A solid LED might just be a "power on" indicator. When you have it hooked up in your error condition, does the charger still charge or does the charger display an error of some kind?
