Thread: Diffs...
GorillaMaxx360
GorillaMaxx360's Avatar
11.05.2006, 06:14 PM
Originally Posted by squeeforever
Definately go with the 1/8th's....Like Troy said, I would recommend the HB Lightning diffs. They are VERY good. Tunability with fluid is a BIG thing if you race as well, so definately get them. Yes, you will probably have to replace the FLM or RRP gears eventually, but not on a daily basis...If you do deside to get the FLM or RRP, go with the FLM...
After looking at the price they are not much more expensive than the flm ones so i decided to get these. Squee will the t-bonz cvds work with these diffs. Does the diff set come with every thing i need to drop them to the hybrid bulks or is there something else i need. as far as oil is black grease a good choice and how much should i put in the gear box. Also what kind/size spur gear and pinions should i use because the 1/8 gears are different ratio right
thanks :027:
