Thread: Diffs...
squeeforever
squeeforever's Avatar
11.05.2006, 06:17 PM
Ok, the Tbonz should work, but I would go UE or MIP. With cerious power, they won't last probably...The only CVD's I'm aware of that don't work are the RD Logics. Also, yes, the diffs ($65ish per diff) come with EVERYTHING you need. the diff, pinion, (not motor pinion, pinion as in ring and pinion), diff shims, etc. Just as oil to the inside of the cups and grease to the gears. Start with something like 10K up front and 5K out back.
