11.05.2006, 07:47 PM
Not much...I would choose the 6mm UE over the MIP. What knuckles are you gonna run? I would run UE Widetrac knuckles. They use a 16mm bearing so it is alot stronger and allows you to run 8mm with only having to get different bearings (bearings that are easily found, unlike the only 15mm bearins they used).
