Thread: Heat?!?
11.06.2006, 11:25 PM
If you're melting solder from the current draw, there is probably a bad solder joint. This creates a resistance, which drops a voltage, which creates heat. Not to mention your system is not getting the voltage it wants due to this voltage drop...
