11.07.2006, 03:16 PM
Originally Posted by nbcaznmaster
i contacted the seller of the balencer. He says that the green means fully charged. also, woudl it really matter if one pack is drained more than the other? hte lvc woudl detect the lowest volt pack and cut it off before the voltage drops too much.
Also, would a rd quickturn work on a e-revo? i was thinking bout making one for my e-maxx center drive shafts.
If you are running both packs in series, then you would have reduced runtime as the pack with less charge will dump first.
The quickturn will work, except if you are using the motor brake, only the back wheels will brake. Also, if you still have reverse, only the back tires will drive.
