Purplefade
11.08.2006, 09:40 PM
The cap is 's a great idea and I like that it's also very light. Couldn't you just tap it and run a 3mm set screw up against the can to help hold it on?? BrianG, you mentioned drilling it above, we're you talking about doing the same thing? Another simple idea that was mentioned was aluminum ducktape, it works good at blocking stuff but is gooyie when it gets hot, aluminum heat tape for furnaces works great!! It is very light, dry type adhevise, made for "hot" surfaces, it's also true aluminum so it disipates (sp) heat very quickly thus not affecting (if it really does by much) your over all running temps. If your concearned about it coming loose you can run a VERY small bead of clear, high temp, silicon around the edge of it to help "seal" it to the back of the can.
Just my thoughts, from other motors I've used, I don't actually own a Neu motor.. yet!
