11.12.2006, 07:44 AM
The one Dafni sells is the the G2r frame of g-maxx
- an Ofna diff with a 51t plastic spur would be the best
- the dogbones; you need to measure yourself what size you need. Mike can hook you up with any length of bone you need
- depending on the motor/speedo/demanded speed/amount of cells you determine what pinion you need.
- Yes, an XL would be a good choice, considering it's price. If you can swing it, a Neu is one of the best motors money can buy for an honest price.
- Okay, not a problem
- 12- 14 and 16 cells? that will require different gearing. Point 3 will need some changing because of this.
14 cells is nice for an MT. You need proper cells.
and if the frame needs to be designed, you can also look at excising dog-bones for your project.
Welcome to the forum you fellow Dutchy..
